Old 05-07-2003, 11:28 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Question zc question.
Ok i'm posting this for another member from the other forums....
"hey i know a couple of you have the ZC i am trying to figure out the distributer problem so i have herd that you cant use the EF distributer but you can use the 88 89 integra. but you have to switch some wires. any one know how to do this or have a link to show me? thanks for all your help from everyone"
Can somebody help him out?
Thanks
Old 05-07-2003, 01:17 PM
mellowboy's Avatar
anybody? I mean come on i know theres quite of you zc owners here!
Old 05-07-2003, 04:52 PM
2000dollarZCbs 2000dollarZCbs is offline
Send a message via AIM to 2000dollarZCbs
i have a ZC but i dont understand the question? you can use a first gen distributor.
Old 05-07-2003, 04:55 PM
Maintenance:
spark plug - ngk bcpr6e-11
timing belt - 14400-pk2-004 (88 prelude)
oil filter - 88-91 civic
oil pan gasket - 88-91 civic si
spark plug wires - 86-89 or 90-93 teg
distributor - 88-91 civic si (with modification) or 88-89 teg
distributor cap - 89 teg 30102-pm7-305
distributor rotor - 89 teg 30103-pm5-a05
head gasket - 88 prelude 12251-pm7-003
intake gasket - 88 teg 17105-pg6-s00
exhaust gasket - 88 teg 18110-pg6-003
water pump 90 civic - 19200-p01-004
ARP Head Stud Kit - VW 1.8 Golf/Jetta 16v WC.
there you go homes.
Old 05-07-2003, 05:43 PM
Cfmotorsports's Avatar
Cfmotorsports Cfmotorsports is offline
Send a message via Yahoo to Cfmotorsports
yes you do have to switch wires, and yes you use the teg dizzy, if you are using the plugs from an si you will have switch the entire plug over from the teg dizzy, just put the wires back in color for color and everything should be ok my problem was the red was wore off the one of the white wires, there is 2 white wires one has a red stripe just besure to get those right and every thing else should fall into place.
MY MONEY PITs!!!
2001 Silverado-----------90 Civic Si
4.8 V8---------------------ZC DOHC Power
K&N------------------------Intake
2" in the back-------------3.5 Eibach
Rollin on 20's--------------15" AR wheels
Pioneer head--------------Panisonic head
JL 10w6--------------------Infinity Ref
http://community.webshots.com/album/49425207zKoYto
Old 05-07-2003, 06:06 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
Originally posted by 2000dollarZCbs
Maintenance:
that is not correct. you use the 89 teg head gasket. I know persoanlly cause i did it.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 05-07-2003, 07:12 PM
mellowboy's Avatar
Thank you
