Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 06-25-2010, 12:43 PM
gdcmf gdcmf is offline
2001 Dodge Stratus R/T A/C light flashing
So last week the light on the A/C knob started flashing yellow and would only blow hot air. I just had the A/C system serviced, added freon and it worked fine for the rest of the day. Today it's started flashing again. However, sometimes when you turn the car off and then on it'll stop flashing and the A/C will work. However this time the battery light and parking brake light came on while I was driving. The A/C was working but I turned it off just in case. Also ever since last summer when it's really hot outside the center console loses power until I turn the car off and on again. Finally when the A/C is working and running it appears to be leaking into the driver side floor. Any ideas?
Old 07-06-2010, 06:09 PM
mayville1 mayville1 is offline
Send a message via AIM to mayville1
Re: 2001 Dodge Stratus R/T A/C light flashing
i have 03 r/t that has been doing the same thing, i cleaned off battery cables because they were corroded, i figured the ac unit wasnt getting enough power maybe. problem hasnt come back in a little over a week now. maybe it helped or maybe i got lucky idk
2003 Ford Escape 4x4
2000 Ford F-250 4x4
1997 Ford F-250 4x4
1995 Chevy S-10 4x4
Old 03-16-2012, 01:31 PM
bacardi4me bacardi4me is offline
my 02 Stratus R/T also has the flashing light. heat can be on and light will start flashing, doesn't seem to matter if AC is on or not. but when its hot out i might get the AC to work for a little bit then light starts flashing and and it will blow warm gross air..been doing this for about 3 yrs and I had taken it in while it was under warranty and they could never find a problem, now it does it all the time i have had it looked at af ew times.. nobody knows why..
