Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-25-2010, 06:15 AM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Thermal Wrap help
Yesterday I put some thermal wrap on my downpipe. When I drove to work it back, it fell off the pipe. The pipe is black now where the wrap was. Like it burned it off, but the box says is can stand up to 2000 heat. The box also had no instructions on it. Do I need to let it sit for awhile after putting the wrap on or something? Do I need to make it as tight as I can on the pipe? Cause basicly I just put it on. And I have heard that some put a hose clamp on the end of the wraps?
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
Old 06-25-2010, 12:20 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Thermal Wrap help
How did you try to get it to stay on? When wrapping, wrap it up tight around, only over lapping no more than a 1/4" as you're progressing
You need clamps. The metal zip ties work great or I guess C-Clamps work as well. Ideally you want to spray the wrap with wrap paint to secure it all together and helps with blocking the heat.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-25-2010, 04:52 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Yea as he said, the metal zip tie strap deals they sell to go with the wrap works good, but its expensive. You can also use safety wire or hose clamps if you wanted. Just depends on how purdy you want it to look.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 06-26-2010, 11:07 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Soak the wrap in a bucket of water before wrapping it. Then use metal ties or worm clamps to hold it one. Once it dries spray it with silicon i think it is to seal the wrap. I never spray my wrap but your suppose to.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 06-29-2010, 01:12 PM
Thanx guys. That was my problem. I didn't clamp it down.
