Old 06-24-2010, 11:38 PM
GeoRandy GeoRandy is offline
Metro Radiator Question of Compatability
I pulled my radiator out because it had a pin hole leak that I had fixed with over the counter stop leak stuff. I don't trust it and want to either have local radiator shop rapair and service it or get a new one.
I have a 97 Metro 3 cylinder/1.0 liter with standard 5-speed transmission.
Here is the question. Is the radiator sold for an automatic the same radiator that a standard uses? I've found a good price but the girl on the phone says she thinks they are different. Does anybody know?
Old 06-25-2010, 04:31 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: Metro Radiator Question of Compatability
I'm pretty sure it mounts the same and will work. The only difference is that an automatic radiator has an oil cooler in it.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 06-25-2010, 07:41 AM
Thanks Woodie. Are there inlet holes for the oil cooler that I'll have to plug?
Old 06-25-2010, 08:48 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
I got a radiator brand new for my manual and it came with a cooler like an automatic should have. Just pretend it's not there. Rad bolts right in.
Old 06-26-2010, 05:26 AM
syrjr1 syrjr1 is offline
Here is a great way to test a radiator for leaks if you need to. Use a bicycle tube. Cut it so the valve stem is in the middle of the tube. Attach the radiator cap and hose clamp the tube ends to the inlet and outlet. Pressurize to test pressure. Usually no more than 16-18 PSI. Soap bubble for leaks.
Old 06-26-2010, 08:38 AM
Now that's smart.
Old 06-26-2010, 08:45 AM
I now understand that both the M/T and A/T radiators will work for my M/T Metro. Thanks for the fast responses W83, JM, and sry. Installing it today. Cute little thing
