Go Back   Automotive Forums Car Chat > GMC > General Discussion
Old 06-24-2010, 01:58 PM
xclodbuster xclodbuster is offline
Transmission Guys Need your Help!
I'm replacing my transmission filter on my 2001 Yukon (4L60-E). While putting in the new filter seal I noticed a small strip of gasket material right in front of the seal that is torn, not sure if it was already torn or if I inadvertently did it. However, I need to know if this has some importance or is it just an overhanging gasket?
SEE PICTURE: The piece I’m referring to is at the end of the screw driver and the tear is just left of the screw driver.
Thanks for any info!
Old 06-24-2010, 02:27 PM
maxwedge maxwedge is offline
A990 racer
Re: Transmission Guys Need your Help!
Not an issue just the edge
Old 06-24-2010, 02:45 PM
Thank you for responding...... should I cut that piece off so it does'nt come off? Not that it feels like it would but just to stay on the safe side.
Old 06-24-2010, 06:55 PM
A990 racer
If it is brittle, looks like it could crack, you could remove it, but this is not normally an issue.
