Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 06-24-2010, 12:18 PM
chuggie chuggie is offline
Cool air condition condinsation inside car
Hi
I have a 2003 eclipse spider convertible that the airconditoning condinsation is leaking inside my car on the driverside. Can anyone tell me how to fix this? I cant find the hose where it should be draining from. Does anyone have a picture out of a macanics manual or something.
Thank
Old 06-30-2010, 09:20 AM
stephaniefl6555 stephaniefl6555 is offline
Re: air condition condinsation inside car
I don't know the technical name for this but the drain hole is under that thick black felt that is next to the fire wall almost directly in the middle. you can pull that black stuff up from the bottom and you should see it. After we pulled it up we noticed that the water was dripping and draining down the fire wall and seeping back into the lip that's under the drain hole. I had it bad in my eclipse, mold and about 3 inches of water in my back floor board. All we did was get a piece of hose that fit tight inside the drain hole and cut it about an inch away from the drain hole. And i haven't had a problem with the water since, but i did have to do a lot of cleaning.
