Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 11-01-2001, 05:51 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
spring rates
how do you know which spring rate is best for you? for coil overs, does making it lower change the spring rate?
1.6 - The Underdog
GA16DE-T Club!
Old 11-01-2001, 11:14 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Lowering the car won't make the spring rates higher. But when you lower the car, you should raise the spring rates, to keep from bottoming out. I have my car lowered using Groudn control coil-overs and agxs. I am running 340lb front springs, and 250lb rear springs. I know others are running softer springs, but i also don't know how low their car is, in comparison to mine? How low you want to go, will affect what spring rate you should get.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-02-2001, 12:33 PM
P10DET's Avatar
P10DET P10DET is offline
Right now I'm the only one I know running lower rates on a P10. I found the 340/275 too jiggly for my tastes, so I'm now running 275/200.
I have the car as high as I can get it with the GCs and those springs. It's still pretty low. I'd like it about 1/4" (.5 cm) higher. Most of my bottoming is gone, but I think the extra 1/4" would make a big difference. I'll probably try the Koni closed cell foam bumpstops. They are progressive and may be all I need.
I really like the lower rate. Other than the very occasional bottoming, they feel extremely good.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-02-2001, 08:45 PM
Beige4dr Beige4dr is offline
I have a '91 P10 with AGXs and just started to install my Ground Controls tonight. I went with 300 front/225 rear (based on some solid sounding advice from people in the forums like George). Hopefully I'll be able to tell you how they are by the end of the weekend.
Old 11-02-2001, 09:02 PM
P10DET's Avatar
Re: 300/225
Wicked cool!
Where are you located? I'd love to see what the difference between the 275/200 and the 300/225 is.
George Roffe
Houston, Texas USA
00 328i
Old 11-03-2001, 01:36 AM
ricecube77 ricecube77 is offline
Send a message via AIM to ricecube77
Geo, i still hafta see how your car handles with that low of a spring rate
Old 11-03-2001, 05:42 AM
OG20's Avatar
OG20 OG20 is offline
I've been running intrax/agx for about a year and a half now and just ordered some 340/250 GC's. Does anybody know what the front/rear spring rates of the intrax's are? I know they are way too soft for their height. I'm just trying to gauge the difference by using the intrax rates to compare.
Old 11-03-2001, 05:19 PM
JustinP10's Avatar
There is no comparison. I went from the intrax to the GC/AGX combo and the ride quality was soooooo much better with the gc/agx combo it wasn't even funny. The GC's feel softer... as they are not always on the bumpstops like the intrax were (for me).
Justin McClanahan
95 G20
