Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 06-24-2010, 11:38 AM
cm1 cm1 is offline
2000 Sonoma- P0452
Hi guys, you've helped in the past, so here gose:
2000 GMC Sonoma 4.3L, 4x4, A/T,160,000 mi.
It has ap0452 emissions sensor circut, but it only sets a code when the A/C is run, not def., . HELP!!!!!!
Old 06-24-2010, 02:30 PM
maxwedge maxwedge is offline
A990 racer
Re: 2000 Sonoma- P0452
Google the code plenty of info, or do a site search also plenty of info.
Old 06-24-2010, 03:26 PM
hinton08 hinton08 is offline
Firefighter317
P0452 is the code for Fuel Tank Pressure Sensor Circuit Low Voltage. The only possible causes of this code are a faulty FTP Sensor, faulty ECM, or a wiring problem between the FTP Sensor and the ECM. Here is a link to the GM service manual for that code. Hope it helps!
http://gsi.xw.gm.com/si/showDoc.do?d...=Jun+1%2C+2010
Old 06-25-2010, 10:47 AM
cm1 cm1 is offline
I have alldataonline, I've done the pin pont test, every step passes.
Also I forgot to say that the A/C has an exsseive amount of condensasion.
Old 06-25-2010, 12:05 PM
Firefighter317
The A/C shouldnt have anything to do with it. Did you check the harness at the fuel tank pressure sensor and do a drag test on it?
Old 06-25-2010, 04:52 PM
Firefighter317
Sounds to me like you have a problem with your ECM because the circuits that control the fuel tank pressure sensor do not interfere with the circuits that control the A/C. The only place they meet is in the ECM so I'm gonna say you have a bad ECM.
