Old 05-07-2003, 01:30 AM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
good news, bad news
Damnit,
Well, let's start off with good news. I graduated college tonight. That was nice.
Ok, bad news. The motor is making a bad knocking noise around 3000 rpm. When it idles (idling low) the oil light comes on. Checked oil, it was about a half quart low. If you press in clutch and rev to about 3k rpm, it makes an awful knocking noise, I'm thinking it's a rod. Which means, rebuild. Anyone else know what it could be. I thought, well maybe exhaust leak. Doubt it though. It's too late to check right now, gotta wait till morning. Damn this sucks. Maybe this is why it's been getting beat by Si's and ZC's. SHIT!!!
91 hatch Si
D16Y8 SOHC VTEC from 96 civic
ghetto short ram intake, HP Racing header, Sprint 1.5" springs, 15" Rota Slipstreams, 195/50/R15 Dunlop Sport tires.
Old 05-07-2003, 02:06 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Maybe you need your valves adjusted. Congrats on your graduation!
Old 05-07-2003, 03:18 AM
91civicDXdude's Avatar
if the oil light comes on, you have serious problems. it wont normally come on until you are like 3 1/2 quarts low. check your oil pump.
Old 05-07-2003, 05:08 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
HEY CONGRATS M8, CHERLYN TOLD ME
WELL DONE, SORRY TO HEAR BOUT YER CAR BY THE WAY, I AITN GOTTA CLUE WOT IT COULD BE
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 05-07-2003, 11:14 AM
valves...no. It is a knock, not a tick.
oil pump problem, I think so. Thinking the oil pump is going out and oil pressure is low, causing a spun rod bearing. Bad news but "live and learn". I'm gonna try to figure it out today.
91 hatch Si
Old 05-07-2003, 11:41 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
oil lights coming on because its idling too low, turn the idle mix screw on the throttle body up a notch, watch your tach and udle specs should be on your hood...like 800 rpm when warmed up i do believe....my rex was doing the same...the knock however may be a problem...time for a d series swap...hehehehehhe
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 05-07-2003, 01:29 PM
d series swap, hmmmm....that's what I have. a 96 sohc vtec. I'm about to drop the oil pan in about 20 minutes after oil drains and it cools down. From there, I will try to take some digi pics to post on here. Me and my buddy at www.speedzonefl.com (shameless plug) both think it is a rod bearing. If so, it may cost upwards of $100 to fix...doing the work myself. Wish me luck.
91 hatch Si
Old 05-07-2003, 02:30 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Yeah it's a rod....if you keep driving it give it a day or so before the rod comes through the block, you probally spun a bearing.
Old 05-07-2003, 02:50 PM
enigine is tore down now. It was the main, rod bearings, everything. Time for some eagle rods, SRP pistons, p&p manifold and head, yadda yadda. Money's going down the hole.
I'm out like a boner in sweatpants!!
91 hatch Si
