Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 06-24-2010, 10:40 AM
ka9mgd's Avatar
ka9mgd ka9mgd is offline
Registered User
Axle Noise when turning
I have a Clicking noise in the axle I presume, I have the noise whenever turning left or right.I replaced the axle on the left side because of a missing cv boot and all 3 mounts have been replaced and adjusted several times-Still no help.Is it possible the right axle is bad?The noise sounds as if coming from the left side.The stabilizer mounts are worn some what,But none in town to buy without doing a special order.Ball joints seem to be OK.This problem is on a 1994 Dodge Spirit-2.5 liter engine.
Old 06-25-2010, 10:29 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Axle Noise when turning
It's possible the right side is bad and you're just hearing that through the driver's window. You might also have a bad wheel stud; check to make sure that none of your studs are cracked, and that the nuts are on tightly.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-10-2010, 07:01 AM
vids1386 vids1386 is offline
you need to Replaced both Link Rod ends on the front stabilizer bar
and also Front Axle drive shaft and Union Nut need to be replaced.This may solve your problem.
used pickup trucks
