Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 06-24-2010, 06:35 AM
gpartin gpartin is offline
Transmission? 1642??
Have a 200 kia sportage automatic and while drivingyou cannot shift into reverse or nuetral, although if you turn off engine , then move key forward, you can shift into nuetral at that point, had the code checked and got a code 1624
Can anyone help????
Old 07-03-2010, 04:50 AM
LMP's Avatar
LMP LMP is offline
Re: Transmission? 1642??
P1624 MIL Request Signal From TCM To ECM
NOrmally you should have anther code with that one.
Do you mean you cannot manually move the shift lever ? I'd check linkage and blocking solenoid .
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 07-03-2010, 06:44 AM
Thanks I had a friend check the linkage and cant seem to find a problem , he said. Acually after the engine is running if you put it in reverse, or nuetral they act as Drive......again though without the engine running nuetral works fine so you can roll backwards. I guess i should get the codes checked again its just sitting in my drive , pretty useless to me at this point
