Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-23-2010, 10:28 PM
9502chevy 9502chevy is offline
96 suburban o2 code
hope you can help. 96 suburban 454 setting P0157 code. i just finished fixing the intake manifold gasket. would this be something with o2 senser? thanks cjc
Old 06-24-2010, 07:54 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 96 suburban o2 code
Yes.
Bank 2 sensor 02 circuit low voltage.
Check wiring to sensor real good.
Have you cleared code and see if it or any other codes come back?
MT
Old 06-24-2010, 04:13 PM
yes, after the i did the intake gasket i had the battery disconnected for two days. it came back so i had cleared with a scanner tool yesterday to find the code. the truck has 145,000, since the gasket leak was at #8 would it be wise to just change the senser or should the upper senser gone 1st. but i will ck the harness thank you. cjc
Old 06-24-2010, 04:54 PM
MT-2500's Avatar
AF - Advisor
I always like to check the wiring and plug in to sensor first.
Good Luck and let us know how it goes.
MT
Old 06-24-2010, 07:16 PM
777stickman 777stickman is offline
If you find the wiring OK I would suggest swapping both #2 sensors (downstream of the cats). If the problem stays on bank 2 after swapping the sensors then you have a lean condition on that side of the motor. Or if you get a P0137 after you swap the sensors then change the sensor.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-24-2010, 11:42 PM
ok, so i swapped the o2 sensers. i guess we'll see what happens next. thanks guys for the help. cjc
Old 07-20-2010, 10:03 PM
THIS IS A THANKS TO ALL WHO HELPED WITH PROBLEM! update . i had switched o2 sensers and took off on 3000 mile round trip from north idaho thru reno to S.F. then to yosemite down to mojave to L.V. where i had a programer ck the computor for codes it had indeed changed sides i replaced the o2 senser and continue on back to idaho. no problems. thanks again guys.
Old 07-21-2010, 09:32 AM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back how it went and the fix.
Glad to see people post back how it went and the fix and do the proper testing to find the problem.
Good Luck
MT
