Old 06-23-2010, 04:58 PM
tamdak79 tamdak79 is offline
Question 2003 Alero-Shuddering problem
I have been recently noticing for a couple weeks now that when I get up past 75mph, I have a shuddering problem. This also seems to happen if I brake from speeds higer than 55mph. Does anyone have a clue what could be causing this?
Thank you
Old 06-23-2010, 08:40 PM
baron1701 baron1701 is offline
Re: 2003 Alero-Shuddering problem
Tire balance at about 72 can really mess up the ride. In my exp. you can be fine up till about 68 - 72 an then instant annoyance. The pads can also cause imbalance. Anything seems to be a problem at that speed. It is a sweet spot for shaking.
Old 06-26-2010, 08:07 PM
Larson17's Avatar
Larson17 Larson17 is offline
If your tires are imbalanced, you'd notice it around 40-50 mph (once you reach highway speeds mostly). Brake pads won't cause imbalance in the tire because they're not rotating with the tire, they sit stationary on both sides of the rotor. Is the shuddering coming from the suspension or engine?
