Go Back   Automotive Forums Car Chat > Kia > Sorento
Old 06-23-2010, 04:33 PM
gentlejax2 gentlejax2 is offline
06 crankshaft bolt broke ? is this common with less than 60K ?
this is the continuation of my co-workers Sorento with 55K miles that suddenly died this week.
At firtst they said it was the timing belt...now they are saying the crankshaft bolt broke and part of it is stuck in the driveshaft...
they are going to do the timing belt now and charge her $100 labor .....and $120 for the part( I guess she was talking about the timing belt)
I dont think she should have to pay for any of it since its under warranty but am I wrong and are they stealing from her?
I feel like they are going to get paid for the repair by Kia and make extra off her and call it a bargain.....
if this is part of the crap shearing crankshaft bolt issue then the should pay for it all except the timing belt part...which she should pay...
I really just want to know if this is a common known issue with this car....
just trying to help her out
Old 06-24-2010, 06:50 PM
RahX RahX is offline
Re: 06 crankshaft bolt broke ? is this common with less than 60K ?
There was a recall on thee crank bolts. I the broken bolt is the root cause and the dealership knows it immediately get Kia corporate involved and raise hell I it is still under warranty. Sorry my phone does not like to type if for whatever reason.
Old 06-24-2010, 06:54 PM
Gah can't edit. The bolt should not have broken. Kia wont cover the belt If it isn't damaged. Repairs related to the broken bolt should be covered If the vehicle still has warranty. They do not break I they are the newer style bolt post recall unless they are overtigtened or incorrectly installed.
Old 06-01-2011, 06:29 PM
Blxcksunshine's Avatar
Blxcksunshine Blxcksunshine is offline
Send a message via MSN to Blxcksunshine
My 2005 spectra5 had a similar problem, the crankshaft sensor broke and went into the motor...pretty much destroying the block.Lucky for me it was still under waranty and kia was happy to replace everything free of charge, including block new crank shaft oil pump...everything. good luck!
Old 09-19-2011, 04:17 PM
FanscapeDerek FanscapeDerek is offline
Kia Optima New Hybrid Mythbusters App!
Hello!
I am working with Kia Motors to spread the word about Kia Optima’s new Hybrid Myth Busters Facebook app: http://on.fb.me/HybridMythBusters
The Hybrid Myth Busters app puts your hybrid knowledge to the test! You can take the quiz which consists of a series of questions related to common hybrid myths and you can even challenge your friends! Now you can finally confirm and deny the rumors you’ve heard about hybrid cars.
The Optima Hybrid is a stylish and value-packed vehicle and readers of AutomotiveForums.com will have the chance to learn more during their car shopping activities. For additional information about the Kia Optima Hybrid, please visit http://www.kia.com/optima-hybrid.
Happy Driving
Derek
Old 10-05-2013, 02:48 PM
rhandwor rhandwor is offline
When my tensioner broke I changed the timing belt and tensioner. The threads in the crankshaft were bad I run a tap into the crank shaft and cleaned the bolt.
The bolt threaded in by hand. I think the water pump had been replaced so I can't say how the threads were damaged. Its very easy to break a bolt if the threads were bad.
My alldata recommends changing the bolt every timing belt change. But bolts are not a problem with other companies vehicles.
