Go Back   Automotive Forums Car Chat > Nissan > Nissan Cima | Nissan President | Infiniti Q45
Old 05-06-2003, 11:07 PM
victor cohen victor cohen is offline
need 1991 infiniti q45 fuel injectors
HELP
I HAVE A 1991 INFINITI Q45 AND HAVE REPLACED ONE FUEL INJECTOR.
I JUST FOUND OUT THAT I NEED TWO MORE REPLACED. I THINK MY BEST BET IS TO REPLACE ALL SEVEN AND NOT JUST TWO.
I WAS TOLD THAT THE ONE THAT WAS REPLACED HAD "NO COLORED DOTS" ON IT.
IF I CAN FIND SEVEN OTHER NEW ONES WITHOUT COLORED DOTS, THEN THAT WOULD BE OPTIMAL.
OTHERWISE I WILL BUY A SET OF EIGHT.
HOPEFULLY SOMEONE HAS SOME THAT THEY WILL SELL FOR LESS THAN THE DEALER PRICE.
THANKS
Old 11-27-2005, 03:38 PM
tyq4591 tyq4591 is offline
Re: need 1991 infiniti q45 fuel injectors
Originally Posted by victor cohen
HELP
THANKS
how did you know they neededto be replaced tell me all the symptons
Old 12-07-2005, 11:59 PM
maxnix's Avatar
maxnix maxnix is offline
Fuel injectors are a wear item, so replacing them with used means you will be repeating the removal of the plenum again sooner.
How did you diagnose them? How are your KS, fuel pump, and the rest of the fuel system? What is your maintenance history and where are you located?
Might as well replace all the under plenum along with the KS and harness while you are in there to avoid repeat labor.
For injectors, get them from www.everythinginfiniti.com, but be sure of your diagnosis first.
Brian
1995 Q45 & Q45t 2000 Q45
