Go Back   Automotive Forums Car Chat > Pontiac > LeMans
Old 06-22-2010, 09:00 PM
pontiacjoe pontiacjoe is offline
1967 pontiac lemans convertible
I need to drop the steering column in my 67 lemans and can't figure it out
Old 06-23-2010, 11:51 AM
maxwedge maxwedge is offline
A990 racer
Re: 1967 pontiac lemans convertible
Look under the dash should be a bracket holding the column up, no? Under the lower column cover.
Old 06-23-2010, 04:51 PM
I have removed the bracket holding the column to the dash and can wiggle the column up and down a little but need to drop for clearance to remove gauge bezel.
any other suggestions would be appreciated.
Old 06-23-2010, 06:49 PM
A990 racer
The column can only go so far down as the connection to the " rag joint at the steering box and fire wall hole limit the movement, you may have to disconnect it at the rag joint and pull it up some, not sure, maybe remove the steering wheel?
Old 06-16-2013, 05:53 PM
GTOHunter GTOHunter is offline
Send a message via Yahoo to GTOHunter
Once You loosen it from under the dash You may have to un-bolt it from the firewall to drop it down further?
