Old 06-21-2010, 05:49 PM
glc4123 glc4123 is offline
1997 pontiac grand prix code 121
yes, my 97 pontiac grand prix has been coding out the code 121 i replaced mass flow sensor and still problems. before i replaced it would hesitate and stall at times. i also cleaned the throttle body with cleaner before replacing sensor and since then the car when starting up engine will fluctuate, when putting on a/c. the engine wil run fine after driving,when turn off and restart after a few hours it wil again start to flucatate. my question is could the throttle body position sensor be bad?
Old 06-22-2010, 07:43 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1997 pontiac grand prix code 121
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
a P0121 is a problem with the throttle position sensor not the MAF, so to answer your question yes, the TPS is most likely your cause.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
