Old 05-06-2003, 08:40 PM
Zum_speed Zum_speed is offline
Question D16y8 question
I posted a thread a litle while ago about engine swap for my 88 civic Lx(sedan) so now after checkin out my possibilities , im thinkin of doin a d16y8 swap....I thought it would b a good swap since its pretty cheap and it would still give me a litle bit more power than my stock engine.....I was wonderin if this swap would b a direct bolt on with my tranny and evrythin else. I was also wonderin if there are a lots of aftermarket stuff for it and would it support turbo or NOS ??
Thanx!
ZUM_Speed
Old 05-06-2003, 10:07 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
there is pretty good aftermarket support for it, it would support nitrous and or a turbo but with proper building unless your gonna run low boost or a low shot, there is however more aftermarket support for the z6 also SOHC VTEC, if you plan on going crazy with this thing i would recomend a z6 if you just want some bolt ons and some nitrous you can stay y8, either is a good swap
2002 Acura TL Type S
1991 Honda Crx Si
Old 05-06-2003, 10:11 PM
91civicDXdude's Avatar
go with the y8. there is the same aftermarket support because they are essentially the same engine with a couple of changes. Also, if you plan on NOT converting to OBD1 or OBD2, the y8 is a better choice because your stock distributor will bolt on with no problems.. with the z6 you have to do some hacking at it to make it fit.
Old 05-06-2003, 10:13 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
from what I hear the z6 is easier to wire.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 05-06-2003, 10:16 PM
its exactly the same. I belive the y8 might have a knock sensor since its OBD2, but not sure.
they are essentially the same engine.
Old 05-06-2003, 10:18 PM
they dont make that many diff cams for the y8 as they do z6 or even a6 :buck
1991 Honda Crx Si
Old 05-06-2003, 10:20 PM
not sure if you knew it, but you can put any z6 cam in a y8, there is just an issue of cam timing. you'll have to re-degree the cam. its something like 3 degrees off which can be fixed with an adjustable cam gear.
Old 05-06-2003, 10:38 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
it's not the same wiring when it comes to MPFI conversion. honda has that lovely habbit of changing injector impedance (sp?)....so they changed it again with the y8. i have yet to find info that addresses this problem for the dx/lx DPFI on the net....since i have an si we didn't have to deal with it.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 05-07-2003, 12:25 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
but isnt there something about the number of splines wrong on the input shaft or something ?
Team Lonely Drivers
Old 05-07-2003, 11:13 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Everything should be the same...
Just get the P28 ECU and distributor from a D16z6 and a wiring harness from [email protected] Then all you have to do is extend 8 wires and you'll be set up for OBD1. That's what I'll be doing.
