| Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
cam spec question
hello again. so i yanked the engine out of the iroc-z and going to do some major work to her. don't laugh or make fun but i'm building a 335 stroker. got the rotating assembly in last week block is at the machine shop. now looking for a cam. wanting a "thumpr cam" but everyone i've seen ain't computer compatible and i'm needin one to work with my tpi. anyone got any ideas or would i just need to call them tell them what i have to get a custom grind? oh yea i'm going to bend my own custom exhaust too. TRUE DUALS BABY!!!
89 iroc tired tpi 305, 700r-4 and 2.73 posi rearend soon to be my LITTLE RED NIGHTMARE!!!!! (in storage) 99 grand prix silver 3.8 loaded (daily driver with 190,500 miles and going like a top!) POOR COLLEGE STUDENT!!!!!!!!!!!!!!! |
Re: cam spec question
The Thumpr cams are for car show guys, the take sacrifices in drivability, power, and rpm to make the car sound "lumpy" depending on what heads your going to use(if you say stock 305 dont waste your time with a cam) but if you upgrade to something like a worked over vortec head or some thing similar(not forgetting you are limited to 1.94/1.5 valves due to the small bore on the 305) then a cam like the comp hyd roller XR269HR-12 would work nicely(vortec peak in flow at around .480-.500 lift. The part number on the cam is 08-502-8. I can also suggested someone to rune the car, Being the small cubic inch, your are going to be limited on heads not only because of the bore, but the size of the intake runner will also be something to consider. stock 305 intake runners cc somewhere around 155-160, being that you are larger cubic inch, a 165-170 cc intake runner will allow some extra flow, but still maintain airspeed/velocity, The vortec heads have a 165cc runner i believe, and flow very well for a cast iron stock GM head. Just my opinion. ask if you have any more questions.
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
well i went with a comp cams xtreme energy computer controlled 269 but i got an issue. dont know what size injectors to go with i'm thinking 24lbs but its definitaly getting a custom prom.
24 lb ford's should work well.
