Anybody know what this is? (Behind rotor)
I want to replace this part but don't know what it's called. Looks like it's possible part of the frame? It's only attached by a few bolts on both sides (left and right wheel).
Please help. |
Re: Anybody know what this is? (Behind rotor)
1) Link to Recent Post about Replacing It
2) Full Topic Link yep... check that post just a few down from yours. a lot of us have experienced that same issue with a broken front sway bar. |
Thanks. Sorry I didn't look into the other threads, I just didn't have any idea what it was called.
hello your pointing to the sway bar
hard to tell but it looks broken if not & your replacing the links any parts dept will have them if you need the sway bar dealer,junkyard either way not a bad job Good Luck
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
It definitely looks broken. Dont get one from a junkyard or youll probably have the same problem not too far down the road.
I think the cheapest option around at the moment is the Dorman swaybar, which is the same size as the GM Performance Parts sway bar, which is the next cheapest one I know of. The factory diameter swaybar (28mm) from the dealership is at least 100 bucks if memory serves. Both the Dorman and the GMPP version are a 34mm bar and I think around 50-60 bucks. Someone purchased one in the thread that you were linked too.
2000 Oldsmobile Intrigue 3.5 DOHC V6 Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners 1986 Jeep Cherokee 2.8 V6 |
There is a writeup in the tips and maintenance subforum on replacing the stabilizer (sway) bar. You basically remove both links (might have to cut them to get them off), then you remove the midpoint bushings with a wrench. Then you will need to undo the passenger side tie rod end to get the bar out.
You can get a complete new GMPP solid bar with new GM rubber bushings and new rubber midpoint bushings from ZZP for about 90.00 shipped. Thats what I have on my car. When you install it, make sure it goes in line an upside down V in the center. Otherwise its in upside down.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
