Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 06-21-2010, 10:29 AM
zaktom zaktom is offline
94 trans am overheated?
I was sitting in traffic on a hot day. The temperature of the engine was getting hot, but not high enough to turn the fan on and then the engine just cut out. I got a tow home and now it will not start. As I was waiting for the tow, the engine did start, but lost oil pressure right away. I checked the oil level and it is full. Now after sitting for a few days, when I initially turn the key, the oil pressure gauge doesn't even move. As I continue to crank over the engine, the gauge starts to go up like I am pumping up a tire and the engine doesn't start. I do have a leak in my water pump that I haven't had before. It looks like it is coming out of the little 1/8 in hole/indentation on the bottom side of the pump. This is the least of my worries, easy to fix. What could be the cause of the engine not starting?
Old 06-21-2010, 10:48 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 94 trans am overheated?
ahhh, leaking water pump directly over the optispark distributer. Not good.
Old 06-27-2010, 10:33 AM
Turns out the connection between the fuel pump and the body of the car is bad.
Old 06-29-2010, 11:12 AM
wrightz28's Avatar
Cool, but none the less, the water pump is leaking on the distributer, only a matter of time before it becomes a problem.
