Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 06-20-2010, 10:21 PM
Navaconda Navaconda is offline
Starter problem
I just purchased a 2004 Jeep Wrangler v-6 with 58000 miles. when you turn the key sometimes it turns over and somtimes it just clicks in the dash..battery and connections are good. Is this in the ingnition switch or maybe a relay any help will be appreciated
Old 06-22-2010, 03:45 PM
mastertech1964 mastertech1964 is offline
Re: Starter problem
could be the igniton switch or it could be a bad segment in the starter next time its just clicking have someone hold the key in the crank position and give the starter body a good whack with a hammer if it cranks over then you need a starter
Old 07-08-2010, 10:22 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Starter problem
Also, check for any corrosion INside your battery cables. I had a positive cable once that had corrosion 6" from the battery. It looked great - on the outside - until I sliced it open to have a look.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
