Old 06-20-2010, 03:21 PM
krankshaft krankshaft is offline
1997 Accord OBD 2 Jumper Wire
I have a question regarding my 1997 Accord I know it's OBD 2 and have the scanner for it but looking under the passenger side dash it has the same 2 pin connector my 1995 OBD 1 has.
Can I jump this 2 pin connector and pull codes on my 97 without a code scanner the same way I do on my 95 or is this connector for something else?
Thanks For Your Replies.
Old 06-22-2010, 02:30 PM
somick's Avatar
somick somick is offline
Re: 1997 Accord OBD 2 Jumper Wire
I am not sure but believe it is going to work too.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 06-22-2010, 09:00 PM
Thanks for the reply it did work.
So it's good to know if you don't have a code scanner you can still get the codes with the jumper wire trick.
