Old 05-06-2003, 05:10 PM
canned4thgen's Avatar
canned4thgen canned4thgen is offline
Send a message via AIM to canned4thgen
Unhappy need help... car running extremely rich
well we got the d16a6 in my car and the think is running extremely rich. it smokes black and the plugs are black as hell. n e ideas on what could be causing this?
Old 05-06-2003, 05:14 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Could it be a problem with the throttle position sensor? Maybe that sensor thinks the gas pedal is on the floor and is dumping in lots of gas.
Is your computer flashing any codes?
Would a bad Oxygen senser cause this?
Beats me. Since I don't have anything to contribute, I'll shut up.
Flunky
Old 05-06-2003, 05:20 PM
Venger10 Venger10 is offline
Clogged fuel pressure regulator??:alien2: Bad O2 sensor would show up as running mega rich at idle or part throttle only , the ECU does not read the O2 at WOT....
Misadjusted TPS would cause the car to high idle also......
Old 05-06-2003, 05:35 PM
its not idleing high at all. its actually idleing really low. and the only code im getting is the one for the vehicle speed sensor
Old 05-06-2003, 05:37 PM
Replace it and see what happens.....:alien2:
Old 05-06-2003, 06:53 PM
i called the honda dealership around here and they told me that our cars do not have a speed sensor or some shit. but its giving me a code for one
Old 05-06-2003, 08:19 PM
91civicDXdude's Avatar
bs, its right on the top of the tranny.
Old 05-06-2003, 08:32 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
mine did something similar to this and it ended up being the distributor. I could hardly drive it running like that, and it shot pieces of the cateleytic converter out of the exhaust.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 05-06-2003, 08:59 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
How long have you run the motor for ? Run it for a good 1/2 hour and see if it clears up. After that check your vaccum lines.
Old 05-06-2003, 09:21 PM
well it has been run for more than 1/2 hour. i have been driving it all week to school
Old 05-06-2003, 10:34 PM
aces1980 aces1980 is offline
The vehicle speed sensor is located in our gauge cluster. Does your check engine light come on and stay on while driving?
Old 05-06-2003, 10:40 PM
yep after about 5 mins of driving
Old 05-06-2003, 10:59 PM
well if u get a new cluster that will get rid off that code. Is that the only one u get?
Old 05-06-2003, 11:10 PM
yeah thats the only code that im getting, but the speedo cable isnt turning so something is wrong in the tranny i think... would that make the speed sensor code cause the speedometer isnt working?
Old 05-06-2003, 11:13 PM
its probably not plugged in all the way. my friends CRX did the same thing when they changed the clutch and unplugged the VSS. the speedometer didnt work and it threw a light. they plugged it in all the way and it fixed the problem.
