Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 06-19-2010, 10:43 AM
Matt R Matt R is offline
2004 Durango Differential
How do i change the rear differential fluid on a 2004 Durango?
How do I change the transfer case fluid?
Old 07-03-2010, 10:31 PM
N8ECH N8ECH is offline
Re: 2004 Durango Differential
Hi Matt:
To change the differential fluid, I recommend getting an inexpensive lube pump at your local auto parts store and then pumping the old stuff out.
You can also use the same pump to out the new gear oil back in. Mobil 1 and Royal Purple gear oil are both synthetic and work well.
For your T case, you will need a 3/8th hex allen wrench that will removed the two allen plugs on the rear of your T case.
After draining, reinstall the bottom plug and then fill till it begins to run back out of the upper hole with Valvoline ATF+4.
Your rear axle will take about 70 ounces, and the T case will be about 3.4 pints.
Don
Flame Red 2004 Hemi Durango SLT 4x4
w 3.55 gears.
Old 07-04-2010, 05:16 AM
pkucan pkucan is offline
Hi Matt,
Make sure you remove the fill plug first.
You don't want an empty t-case and then find out the fill plug won't come out.
Just a precaution.
Old 07-06-2010, 09:56 PM
PK:
Very good point. Although I have never run across this, I think I will add it to my SOP for such processes.
Thanks Don
w 3.55 gears.
