Old 06-19-2010, 08:24 AM
ELCBOSS ELCBOSS is offline
94 LaSabre AC Problem
I have a 94 LaSabre with ac air discharge problems. When first turned on eveything works just fine. After a few moments the air will move to the defrost vents and no matter what you do it will not move to any other position. Once the car is parked for a bit, it might or might not blow from vents. I have checked the vacumn and it is good. Any ideas? If it's the dash switches or vacumn manifold on the controler how do you get to it?Thanks for any responce.
Old 06-20-2010, 06:35 AM
C man C man is offline
Re: 94 LaSabre AC Problem
Could be the climate control unit itself. Mine had the same symptoms. Some times it would take a while and other times I would have the exact same experience as you're having. Got one from the junkyard for $12.
This is a link to my thread http://www.automotiveforums.com/vbul...d.php?t=954958.
Don't no if you have the digital readout or the manuel one. But I would assume both are prone to failure.
You would pass out if you knew the price on a new unit. $500+
95' PARK AVENUE 168,000 MILES
Warning : Listen at your own discretion
Old 06-21-2010, 10:54 AM
imidazol97 imidazol97 is offline
AF -Advisor
Check your vacuum hoses on the motor and firewall for cracking. When vacuum decreases the inside vacuum motors default to the settings that assure defroster working for safety.
Typical, if no vacuum lines cracks, is the vacuum connector ont he corner of the programmer box next to the heater box.
http://www.imcool.com/articles/airco...acuum_line.php
Some have used aquarium line to connect the tubes inside the programmer with those outside to just cut the multiconnector out of the picture.
You can verify that the vacuum is adequate by starting motor then turning it off and leave the key ON. Immediately start switching between settings on the AC control. You'll hear the vacuum motors moving for heater on floor and bilevel and the recirculate (it takes about half a minute because of a porous plug in the line to slow its application and release).
You can even take one of the other vacuum lines or run one from the motor and apply it to the blue line vacuum motor above the accelerator pedal. When that one applies, the floor diaphragm has to be closed to force air upward and then out the dash.
