Old 05-06-2003, 11:20 AM
fwdfreak's Avatar
fwdfreak fwdfreak is offline
Send a message via MSN to fwdfreak
possibilites to can-clearcoat over an airbrushed enamel???
man i've tried dozens of things, mixxed nailpolish and enamel then cleared it it all turned gray but didnt react as made ´'waves' on the body. then i just tried thinning enamel with laquer thinner didnt work either, there has to be some way to mix enamels with something that a can clearcoat won't react with it
Old 05-06-2003, 12:05 PM
sugarcaddy's Avatar
sugarcaddy sugarcaddy is offline
What type of clearcoat are you using? That might be the problem. If your using a lacquer based clear coat that wont work over enamel. Try a enamel based clear if this is the case. Also a different approace would be looking into different ways of obtaining a gloss, like floor polish or a ceramic glaze.
I use a triple thick clear glaze that adds a glass-like finish to my models. I apply 2-3 coats then sand-polish-wax. The glaze will go over all types of paint with no side effects to my knowledge.
WARNING-this stuff will drip big time if not applied carefully. Test out first before using on a model.
Scott
Fastest hunk of junk in the Galaxy.....
Old 05-06-2003, 12:12 PM
fwdfreak's Avatar
they dont sell enamel can-clearcoat here to my knowledge, mine is arylic
Old 05-06-2003, 12:15 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Just apply few mist coats of spray (Tamiya synthetic lacquer or Testor lacquer) until you build up a protective layer, then spray lightly for the rest.
Gunze has water based acrylic spray, called Top Coat. Try it, if it's available near you. I think Future floor wax doesn't dissolve enamel either, but I've never tried it, so I'll leave it to someone else.
Hiroaki Fukuda
Old 05-06-2003, 12:19 PM
fwdfreak's Avatar
can't get any of the stuff u named hiro but thanks anyways
Old 05-06-2003, 12:56 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Humbrol makes enamel clear
And it's readlily available.
Old 05-06-2003, 12:59 PM
fwdfreak's Avatar
i want enamel thats air-brushable
and that humbrol shit dries way 2 fuckin long, 1week
Old 05-06-2003, 02:20 PM
fwdfreak's Avatar
i don't wanna say anything yet but my second attempt on lquerthinner and enamel + acrylic clear is working
Old 05-07-2003, 04:09 AM
fwdfreak's Avatar
YUP!! it didnt react!
Old 05-07-2003, 09:45 AM
theoldboy theoldboy is offline
this may help
i use tamayia clear from the jar,thin it with clear metholated spirits
i use it overall paint surfaces i have never had a problem
you will need bright sunshine for it to dry if you live in a humid climate as can get a milky appearence you can usually sand and polish after 24 hours. enamel clears usually have a yellow ting to them and used over light colours looks terable
