Old 06-18-2010, 05:16 PM
mrgranite04 mrgranite04 is offline
89 chevy pick-up wont start
89 Chevy 1500 acts as if running out of gas. Once motor stops, will turn over when cranked but will not start. Replaced fuel filter, relay & fuel pump. When key turned forward fuel pump wont turn on. What could be the problem?
Old 06-19-2010, 10:24 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 89 chevy pick-up wont start
Check for voltage at the pump during initial key on (engine prime). If there is no voltage, try to trace back the wires. I have heard of faulty ignition switchs causing no voltage issues.
When the pump dies, do you also lose spark?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-29-2010, 06:09 AM
yukon45427 yukon45427 is offline
my trucks doing the same thing ok i just fixed mine try pliceing into the ground wire and running a wire to the frame thats what just fixed mine
