Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 06-18-2010, 12:36 PM
tomvid tomvid is offline
97 Wrangler High Idle HELP!!!
I have a 97 Wrangler. The other day it started to idle high. It Idles at 2200 rpm. It is not speratic. It runs just like it should but at 2200 RPM. I think it may be a vaccum leak somewhere but I looked everywhere and couldnt find one. Another thing that is puzzeling me is that I have no check engine light on. I did some tests on the Throttle Position Sensor and ruled that out as the problem. Any suggestions would help out greatly, I am stumped on this one.
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
Old 06-18-2010, 02:02 PM
mastertech1964 mastertech1964 is offline
Re: 97 Wrangler High Idle HELP!!!
if the idle is real high you most likely have a vacuum leak on the intake manifold somewhere either a blown,rotted or disconnected hose or possibly the intake manifold gasket itself but most likely a hose
