Old 06-18-2010, 01:05 AM
amhspurser amhspurser is offline
Inside light won't go out...
1994 S-10 extended cab...
The light in back above wondow won't go out..
could it be anything other than the door switches?
Could the bulb itself cause this?
Or the light assembly itself?
All other light seem fine
Old 06-18-2010, 09:32 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Inside light won't go out...
If inside cab light goes on and off good and works good check for switch on back cab light.
MT
Old 06-18-2010, 01:12 PM
There is a switch on the light itself? You must have to remove it to see it? Seems odd that the light does not have a on/off switch...
