Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > 1969 - 1994 Full size
Old 06-17-2010, 09:26 PM
SuperLift 93 SuperLift 93 is offline
93 K5 Blazer Electronics Issues
Hello Guru's, I have a 1993 K5 Blazer(1500 pkg) with a 1996 suburban engine, 5.7L V8 TBI same connections, but does have an aftermarket alarm. My truck is experiencing problems with the HVAC, Wipers, Radio, and ignition systems cutting on & off by themselves as I accelerate from a standing stop. ABS, Brake and Service engine light all came on @ the same time these problems started. I'm clueless even after replacing modules & sensors??? PLZ HELP!
Old 06-18-2010, 01:40 PM
old_master's Avatar
Advisor/Moderator
Re: 93 K5 Blazer Electronics Issues
When seemingly non-related electrical problems occur, it's usually a ground connection is either loose, corroded, or missing. Check the body grounds: battery negative terminal to the body and engine block. Also check ground cable from engine block to body.
You have to know how it works,
to figure out why it doesn't.
