Old 05-06-2003, 01:35 AM
Davoaldo Davoaldo is offline
Question How do i use this??
um.. i just wanna ask how do i use this stuff cause i jsut found it out of my hobby box.....
what is it??
and also i have this flat base tamiya as well..... X-21 same Q what is it how do i use it??
hehe sorry for newbie questions
Old 05-06-2003, 01:48 AM
RallyRaider's Avatar
Zomby Woof
Just ordered some Mr White Base recently too. Was going to experiment with it a bit and see if it acted as a primer by itself or was better suited to being used as a white base coat over a grey primer. Given the name I suspect the latter. Probably not opaque enough to cover any body mod colour changes by itself.
X21 flat base is intended to be added to Tamiya's gloss paints to flatten the finish. I think they do one for acrylics and one for enamels. Mixing them wouldn't be recommended!
Old 05-06-2003, 01:53 AM
freelunch's Avatar
freelunch freelunch is offline
I've seen this stuff in cans - its like Tamiya white primer.
Old 05-06-2003, 01:55 AM
Chain's Avatar
Chain Chain is offline
Havent tried Tamiya.
All along using Mr Hobby 1000 and 1200 primers in spray cans.
Seems ok to me.
Bottle forms not too sure though.
To each his own!
Read the FAQ you faqer
Evo Meet....coming to a forum near you!
Completed!-Click on Pic:
Projects done and posted:
Subaru WRC2001 RGB-My first project in AF Click Here
In stocks:
Ferrari F1 2001
Tyrrell P34
CLK Warsteiner
Ford Performance Blue
Ferrari Enzo
Opel Team Holzer
Williams FW24
Old 05-06-2003, 03:58 AM
oh..... so.... do i have to thin it down or jsut use it as is??
i fi have to thin it what thinner do i use cause i don't even knwo if its E, A or L
Old 05-06-2003, 05:36 AM
Zomby Woof
Spray it man! Through an airbrush. Have a smell of it - definitely lacquer based so use automotive laquer thinner to reduce it to the right consistancy for your airbrush. Being lacquer based it would dry far too quickly to be any good for regular brushing.
Experiment, try diferent things, you might discover something cool! Or learn Japanese and follow the instructions
Old 05-06-2003, 06:04 AM
daggerlee's Avatar
I have it and used it. It works best sprayed over a gray base. I tried spraying it directly over black, it came out ok I guess. Reduce it with lacquer thinner.
Dan
