Go Back   Automotive Forums Car Chat > Toyota > Highlander/Highlander Hybrid/Kluger
Old 06-17-2010, 09:15 AM
hubert345 hubert345 is offline
engine check and VSC lidht came on
Hi,
On my 2002 Highlander with 68,000 mi the check engine and VSC lights came on this morning. I know that for some cars there is a way to retrieve the cod without hooking up the diagnostic tool, basically by performing a cetain sequence of operations. On a friends car, for example, turning the ignition on/off several times in a row will read out and display the enging check light code on the dashboard display.
Does anyone know if something like that is supported on the 202 Highlander. This is a Limited, 4WD, V6.
Help is appreciated.
Thanks
Old 06-17-2010, 10:19 AM
typesix typesix is offline
Re: engine check and VSC lidht came on
On Highlanders, sometimes the problem can be vacuum hose leak or hose being dislodged, or gas cap gasket. A common one for V6 is hose near the air cleaner housing being dislodged.If there is an Autozone nearby, they will read the code for free.
Old 06-17-2010, 10:56 AM
Thank you for the info ... I'll be stopping by Autozone on the way home from work today ...
