Old 05-06-2003, 01:10 AM
DDogg DDogg is offline
Unhappy Help!!
Just bought a 91 dx hatchback .Where do i start? What are the most important things i should do first???
Accel Wires and distributer
NGK Platinum Plugs
Tsudo coilovers
Tsudo Fireball Cat-back
Custom cold air intake
Kenwood 7" Monitor
Amp's, Speakers, etc.
Old 05-06-2003, 01:31 AM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
depending on how old you are.....BRAKES.....but seriously....brakes, suspension, wheels, then when you get a feel for the car tend to the motor. Thats the smartest way in my books.
89 DX: LS Powered
88 CX: Project ZC
Old 05-06-2003, 01:43 AM
2000dollarZCbs 2000dollarZCbs is offline
Send a message via AIM to 2000dollarZCbs
i agree with slammedcivic, about brakes, the brakes on these year hatches SUCKKK, i have a 91 dx myself, brakes would be first, but the thing is.....which way do you want to go? all show and no go? or go and then show? show then go? which one? but brakes before anything i got a motor and puched it and i had people in the car, and the car litterally WOULDNT STOP? and almost crashed. going down hills with people too...forget it.
Old 05-06-2003, 01:50 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
i disagree, if ur brakes feel ok to you, and u are downshifting instead of braking with clutch in and ur stopping isnt too bad then u should do some basics before you upgrade ur brakes. basics being things like lowering springs and shocks, si gauge cluster so you have a tach, intake and exhaust. How much money do u have to work with?
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 05-06-2003, 06:48 AM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
my brakes feel great.. maybe cause its canadian made :finger:
Old 05-06-2003, 11:55 AM
^^^^^LOL. My brakes are fine!!! Well I've done all the basics to make to car run good, new brakes, new shocks, new filters, oil, coolant flush, new pcv, new alternater, steam cleaned. Heres a pic, I'd like to work on apperance now the car is runin good. What should I do to the exterior first. Shocks? Tires, Rims, body kit? I don't want to get rims and then it doesn't look right or vice versa.
NGK Platinum Plugs
Tsudo coilovers
Kenwood 7" Monitor
Old 05-06-2003, 12:09 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Do the MPFI swap.
Old 05-06-2003, 12:55 PM
cyberfelon's Avatar
cyberfelon cyberfelon is offline
Send a message via AIM to cyberfelon
my brakes are fine, haha i dont know what you guys problems are, maybe yall should learn a little compression braking :finger:
i would start replacing boots and bushings, cuz if your car is like mine, they are all trashed
Id rather be drifting...
Old 05-06-2003, 01:15 PM
cyberfelon's Avatar
definitely sounds like CVs to me, but im not car expert or anything, if your boots were shot then theres a good chance that the cvs are bad too it all depends on how bad the boots were and such. damn i gotta say that hatch looks hella clean, looks like they took good care of it. on the mpfi swap i dunno anything bout that cuz i have an si so it was already mpfi, i know you need to add a few wires, a new intake manifold and an injector resistor box, but thats all i know, theres prolly more to it, sounds like a pain to me. you should come back in the evening when all the smart people are on
Old 05-06-2003, 01:22 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
if its a knocking noise it can be A) wheel about to fall off check your lug nuts or B) bad wheel bearing
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 05-06-2003, 01:26 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
first i would like to say nice car! that is WAY clean! i would agree that it is your CV joint.... also listen with your windows open as you drive on a quiet road at about 20 mph and listen for a slight hissing noise, ilke metal rubbing on metal... like SHHHHHHHH but very quietly coming from that wheel... that can also be a sign of the CV joint going out.
well as far as what to do first, it all depends on how big you want to go. first i would check out your current motor and see if anything needs fixing. check for ECU codes and compression, check the status of your brakes and hoses, when was the timing belt replaced, or has it been?
motor:
on the d15 you have currently, it is hard to get much performance out of the DPFI (2 injectors rather than 4 like MPFI) so the best option is to start off with either a MPFI swap (converting your DPFI to MPFI) or just swapping in a whole new motor with MPFI. this has been covered a zillion times on these forums, just search around.
suspension:
if you want to increase handling and looks, i would suggest new springs and struts. possibly a camber kit. lots of companies make lowering springs for a 4th gen civic. just make sure you do it right--no cut coils please.
brakes:
i think every car ever made could always use upgraded brakes... no one has ever said that they stopped TOO short or TOO fast. getting some new rotors and high quality pads along with some braided steel brake lines and DOT4 fluid can help dramatically. if you need more, you can always do the rear disc swap. there are how-tos of this posted all over.
other than that, it is limitless. just look around and see what people have done. find something that fits your budget and your ultimate goal for your car. have fun with it, make this car a reflection of you. i think the best part about modifying a car is that you take something ordinary and make it special and unique to you.
check out www.4thgenerationcivic.com
Old 05-06-2003, 01:38 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
They replaced both front axels. $400
holy crap! dude start learning how to do some stuff on your own it saves a ton of money! 1st thing you should do in my mind is get a manual for your car
2002 Acura TL Type S
1991 Honda Crx Si
Old 05-06-2003, 04:55 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Tires
Do the work yourself when you can. It cost me $60 for an axle with a lifetime warranty at Autozone, and only took an afternoon.
When a wheel bearing goes out, it makes a noise any time the car moves. Wheel bearing noises are never intermittent.
When a CV joint is going out, it always makes the machine-gun CLICK-CLICK-CLICK, but only when your wheel is turned to one side or the other. CV joints usually don't make any noise when they are going straight ahead.
If you've done your tune up (and your engine looks SWEET, by the way), and you've got good brakes, I say your next step should be tires. Even a great suspension system and good brakes won't help you if your tires are bad. Even if they are new, if they are low quality and not sticky, you'll find yourself sacrificing everything else in one brief moment.
I had one bad scare, and I've been investing in tires ever since. They are your best insurance policy.
Flunky
PS-They'll keep you out of accidents, and keep your insurance rates down, too!
Old 05-06-2003, 04:59 PM
multi point can turn out bad if you do it wrong, you need to wire in two more injectors, but and add a resistor box, and wire that in, and you need to wire in two wires into your ecu plug ins. if you are thinking about doing it, i would suggest going on the internet and getting how to do it, BUT BE CAREFULL, some people lable the wires on the back of the ecu plug ins wrong. they tell you that the plug ins go a1, a2, a3, meaning that top to bottom it goes top a1, bottom a2, and so forth but the way honda does it, its the whole top row is a and bottom is b, i have spend 2 thousand dollars trying to wire a ZC to multi point. what a waste.
i would say lower the car first, take off the honda sticker, and the bra.
other than that, your car is wayyyy clean, congrats, how much did you pay for it?
Old 05-06-2003, 05:55 PM
turbcivic's Avatar
turbcivic turbcivic is offline
KEPP IT STOCK!
(runs away with hand waving widely in the air):evillaugh
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
