Old 06-16-2010, 05:39 PM
mudrunner80 mudrunner80 is offline
busting flywheels
I have an 88 scottsdale 350, 700R4 tranny and for some reason the flywheels are cracking and make one hell of a racket. I checked this last one real good for cracks before I put it on and nothing. now the noise is back. I looked real quick and its cracked in 2 places I can see. I was told it could be the starter but it starts beautiful, no noise or binding. This will be my 3rd one. 2nd in a years time.
I wont be replacing too many more times. Thanks
Old 06-16-2010, 07:26 PM
j cAT j cAT is offline
Re: busting flywheels
use med locktight on bolts..torque to the correct amount..make sure the mounting surfaces are clean no rust...
Old 06-17-2010, 07:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As J cat posted installation can be the problem.
Also always use a new flywheel and correct for you year of engine instead of used one.
Other installation things to check is your converter and transmission dial pins and dial pin holes in transmission and for lose transmission mounting bolts.
Any engine vibration at different RPM when engine is running ?
If so you may have wrong flywheel or a converter or crank pulley out of balance.
MT
Old 06-17-2010, 08:59 AM
post a picture of the cracked flywheel ..
Old 06-17-2010, 09:09 AM
Bob B Bob B is offline
Years ago I had a small block Pontiac 301. Built in 1977 as a light weight meant to be economical. It had a very thin center to save weight.
After it broke the second flywheel, I replaced it with a thicker center version that the factory came out with to stop the breaking.
Old 06-17-2010, 01:42 PM
I will, I already threw away the last one since it was in 2 pieces. They all seem to be breaking in the center and webbing out to the big holes. I'm waiting for the rain to stop. I'm hoping it'll hold out until the weekend but its not sounding promising.
Old 06-17-2010, 01:48 PM
I dont notice much vibrations. I'm also factoring in its 22 years old. I'm replacing the junk 700R4 tranny with a th400. I'm not expecting that transition to go smoothly, it never does but I do know the rear spline is bigger on the 400 is there an adapter I can put on in place or swapping the transfer case? Sounds too good to be true but thought I'd ask anyway
Don
Old 06-17-2010, 08:35 PM
Don
when you install the next flywheel see if you can move it up/down some ..could be worn crank bearing ..
Old 06-18-2010, 08:12 AM
MT-2500's Avatar
AF - Advisor
Don
Going from a 700R4 to a 400 is not a wise move.
You will lose your OD gearing and lose gas mileage.
No adapters to switch transfer case over to a 400 transmission.
Only way is to change the input shaft in transfer case.
MT
Old 06-18-2010, 08:58 AM
I realize I'll be losing MPG and gaining GPM but I will be hauling a mud truck with it and was told by every Tranny shop that its a junk tranny. worst GM ever made and theres nothing they could do do it to make it strong enough. Changing the input shaft is reletively easy from what I was told.
I went with the 400 because it was recomended by every shop I asked. The one I bought has been rebuilt with heavy duty kit.
Don
Old 06-21-2010, 03:46 PM
http://i883.photobucket.com/albums/a...20101902a1.jpgThis one I could explain, I replaced it this past weekend and noticed my Tranny bolts loosened up on me. I did check for that earlier and I could've sworn it was tight but when I started the tear down all bolts were hand loose and one was totally missing. It was backed away from the block about an inch. The cracks up to the "circles are'nt vivible from the pic but you can see its all cracked just around the bolt holes. Not even sure how its still in one piece![/IMG]
Old 06-21-2010, 04:30 PM
MT-2500's Avatar
AF - Advisor
Thanks for posting back how it went and what you found.
MT
Old 06-21-2010, 07:52 PM
consultIII consultIII is offline
seems like you have it solved. If it continues...ballooning torque convertors are common on these trans which can cause broken flex plates. If crank runnout is ok replace the torque convertor.
Old 06-21-2010, 08:03 PM
I BELIEVE THAT THESE LOOSE tranny/engine bolts are your problem ,,,use the medium lock tight on those fasteners as well as the flywheel studs..
this would be similiar to the crank shaft bearings being worn too much movement ..
Old 06-21-2010, 08:37 PM
I did use thread lock last time. Not sure what happened. I checked the crank shaft and there was no play. I'm hoping I figured it out. I will keep my eye on this one and keep you posted. Thanks a bunch guys!!!
Don
