98 lumina
Hope someone can help, i have had so many different opinions and to what is wrong with this car. I had difficult in cranking for weeks and now it want crank, i have had a new key made with computer chip in it and all the car will do is flash the security light. some say i need a new ignition switch but others say that it wouldnt even turn if thats what it was........at my wits end
Re: 98 lumina
Not clear what is happening here, does the engine turn over but fail to start, either way if the sec. stays on that must be addressed.
Re: 98 lumina
the problem is not with the key but the ignition cylinder contacts that the pellet resistor in the key... er...well...contacts. If the contacts are worn the resistance that the theft module gets from the key changes. the vehicle thinks its a wrong key and the engine won't crank.
the problem may have began with intermitant no cranks but would then start after the 3min theft derterrant time out. the dealer will want to replace the cylinder which will need a new pellet key cut to the new cylinder. As you know the keys are $$. |
Re: 98 lumina
these cars also frequently have the wires from the lock cylinder to the theft module break inside the steering column in which case you need to replace the cylinder and fish the wires down the colum
