Old 06-16-2010, 02:24 PM
soyelmismotony soyelmismotony is offline
Smile loss of power 98 caravan 6cyl 3.8l
when going up hill i notice loss of power but when going down hill oh in flat surface van runs fine I got it fix by replacing cam and crank position sensors myself and save lots of cash by not takining it to a mechanic
Last edited by soyelmismotony; 06-17-2010 at 04:50 PM. Reason: got it replace cam and crank position sensors
Old 06-20-2010, 01:59 AM
Re: loss of power 98 caravan 6cyl 3.8l
I paid around $110.00 in Autozone for both sensors save on labor cause I did it myself crankcase sensor is located belowe air filter box and must be removed used a 10 mm socket. camshaft sensor located on pasanger on the upper side. use a 10 mm rench.
Old 06-20-2010, 03:28 PM
ftamike ftamike is offline
Hi i have a 2001 T&C 3.3l that has the same problem(no up hill power ) do think i could have the problem thanks
"I think Congressmen should wear uniforms like NASCAR drivers so we could
identify their corporate sponsors."
Old 07-04-2010, 12:52 PM
Smile Re: loss of power 98 caravan 6cyl 3.8l
it could be because mine if a get enough speed so i can let it off the gas pedal. cleaning the throttle might help too.
my lack of speed came along withan engine light code p0420 a belived cam and crankshaft signal lost.
