Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 06-16-2010, 03:37 AM
Dashvortex Dashvortex is offline
weird noise driving me crazy help!
ive got a weird noise with my recently purchased 04 civic ex coupe. its like a low tone, muffled du-uh-dut sound is the best i can describe it. kind of similar to the dut-uht sound of driving over the expansion cracks on a concrete road but lower tone and a bit quieter. it sounds as if it occurs with every rotation of the wheels and has a slight pause (half a second or less) between reoccuring. it speeds up and slows down with the cars speed but only is noticeable between 45-65 mph and is loudest at 55. it does it in neutral and in gear and brakeing dosnt seem to change it any. the only thing that changes it any it taking a slightly hard right corner at about 55 then it makes the same sound twice then has a shorter pause more like a du-uh-dut-du-uh-dut if that makes any sense. it definitely sounds like its coming from the drivers side rear wheel area so i rotated the tires/wheels around in all different combinations and it didnt change anything about the sound. so i figured it must be a rough bearing or brakes so i swaped out the whole spindle, hub and bearing on that corner of the car, changed the rear brake shoes and hardware and resurfaced the drums and rotors and still have the exact same noise. the car does need an alignment but it doesnt show any irregular tire wear im starting to think it may be a suspension component though i cant find and play in anything and it sounds like a spinning type noise for sure.
any help is greatly appreciated, this sounds driving me nuts!
Old 07-05-2010, 11:16 PM
cherryelky305 cherryelky305 is offline
Send a message via AIM to cherryelky305
Re: weird noise driving me crazy help!
tie rod ends, compliance bushings, struts, could be anything like that. unless you can check it yourself, id take it to a shop that know what there doing.
1980 El camino
2002 LS1 swap
