Old 06-15-2010, 06:37 PM
Greyspapa Greyspapa is offline
BBC No Oil Pressure
I recently lost two of my roller lifters in my A Gas Alter. Needless to say when this happened, it wiped out two lobes on my cam and an oil pump, losing oil pressure.
I replaced the cam, lifters, oil pump, and while I had the engine upside down I replaced rod and main bearings. Got the engine back together, and back in the car. When I first started it up, the most oil pressure I could get was 20lbs. Shut it down, and changed to a mechanical oil pressure gauge, still only 20lbs. I removed the distributor to check the drive and when I recently put the distributor back in and restarted the engine, had about 5lbs. Removed the valve covers, started the engine, no oil at the rockers. I am stumped on this one.
Anyone with suggestions on where to start?? Help is greatly appreciatted.
Regards
Greyspapa
Old 06-16-2010, 01:29 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: BBC No Oil Pressure
Regards
Greyspapa
Did you plastigage the mains when you installed them to check for the proper clearances? If the gaps are to big, it won't build pressure.
Is the oil pump pick-up in the correct place?
I would pull the distributor and use a priming tool on a drill to spin the oil pump to see if it will build pressure that way.
Just a few things that come to mind.
Good luck
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 06-18-2010, 01:12 PM
maxwedge maxwedge is offline
A990 racer
Worn cam bearings would be another issue to check here, or debris in the passages from the cam bearings.
