Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 06-15-2010, 05:19 AM
mikecastner mikecastner is offline
Question gauges gone wild
I have 1998 Plymouth neon it does this more in the hot month than the cold month but I am drive down the road and the dash cluster will go out no tach, speed, no gauge, mileage will not work but all dash light, signal light, high beam all will work. It seam that when it cools off some, some time a minute some times a few minutes when it comes on the seat belt and air bag light come on or you can turn off the key for a few seconds and it will come on, bums will not make it go out or come back on. What can it be?
Old 06-15-2010, 06:26 AM
Oldsmobile Doctor Oldsmobile Doctor is offline
Re: gauges gone wild
Check this thread it worked for me..Thanks das2123
http://www.automotiveforums.com/vbul...hlight=cluster
Old 08-15-2010, 03:27 PM
typete02 typete02 is offline
Had the same problem with my 1996, I am told the neons are good for this. I took the dash cluster out and resoldered a couple of pins based on what I had found on the internet. There was a couple of pins that had obvious solder cracks, once I fixed this it has been working just fine. I think it was on youtube that I found the process.
Old 02-26-2011, 04:17 PM
danz409 danz409 is offline
ok. i just recently bought myself a 99 neon. great car! sounds and feels like its in a SOLID running order mechanical wise. however. there are a few problems with the car. one of which is the instrument cluster. and that is a very useful video. however i can't seem to find the normal means of removing the cluster from the car itself. i only can find 4 screws on the lower panel under the steering wheel. anybody know where i can find a guide or tutorial on how to remove the panel in a non "HULK SMASH" fashion?
oh and other 99 neon owners beware... this car isn't a very good boat.. or anything else that's water proof.
this thing gets pools in it with the slightest of rain... at first i was wandering what the "no diving" sticker was doing on the back of the headrest... it all makes since now. in fact. I'm keeping it there
Old 02-26-2011, 07:00 PM
Dash pad pulls up than pulls to the rear. As for the water the tail lights leak at the seal to the body.
Old 02-26-2011, 08:44 PM
thanks. ill have a look at it tomorrow. I'm experienced with soldering. work with electronics commonly so that part should be a breeze. as for the seal around the tail lights. i know the one around the truck was kinda messed up. i fixed it today... kinda, it needs glued so it won't keep coming off. would that of caused the water?
the passenger side mirror is also off. i had a friend pour a bucket of water on the car wile i was inside looking. i saw some trickle between the door and body but none came in.
Old 02-26-2011, 10:10 PM
when i saw the title of the thread.. i loled a bit. then made this.
Old 02-27-2011, 12:16 PM
worked like a charm. got to it easly. and soldered in no time. however i don't think thats the problem. it looked good. but i did so anyway to prvent it in the futor. i think the problem might be the computer is too wet or something on the computer end. takeing rest of the dash apart now to find it and have a look at it.
Note: the plastic used in these cars is extremely fragile!
the slightest bend trying to remove it from the car due to those friction tabs cracked the thing all the way down...
Old 02-28-2011, 12:02 AM
anybody? please. i could use this car to get me from A to B knowing how much gas i got and how fast I'm going. may need to do some long distance traveling here soon
i looked over everything. re-soldered connections it all looks good. connections are solid. board looks good. fuse is good. only thing i haven't been able to check is the on board computer.
Old 02-28-2011, 12:03 AM
Old 02-28-2011, 07:55 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
You may need to add some solder to the pins. But all you really need to do is heat it up and watch for the color change. That should take care of the problem.
2003 Dodge SRT-4
Old 03-01-2011, 09:29 AM
already did that. added solder to all the connectors and any that didn't have much
Old 03-18-2011, 05:20 PM
DAVE K DAVE K is offline
The o.p. looks like I wrote it,I've been giving it a rap but have wondered if there was a fuse that was bad.I assume the speedometer is hooked in to all this?most the time I drive by the tach when it is working.
Here lately though none of the gauges work sometimes. But mostly just the speedometer.
Old 03-18-2011, 11:32 PM
Dave K, if just your speedometer and odometer aren't working you need to take a look at your VSS (Vehicle Speed Sensor). It is located on the rear portion of your transmission on the driver's side. It may be disconnected, oil may have gotten in there or it may have gone bad on you. It is held in with 1 10mm bolt.
2003 Dodge SRT-4
Old 03-18-2011, 11:45 PM
Thanks I will check it out.Silly question though:would that affect the fuel gauge and temp.gauge?and fix itself when I rap the dash?You bet I will look at the VSS.Sorry das guess I didn't mention that my fuel and temp. gauges would quit working.
Many thanks
