Old 06-15-2010, 02:36 AM
pos-truck pos-truck is offline
05 z71 with fuse box problem
every once in a while (especially when hot) ill turn the key on and the fuel pump wont kick on, the headlights and cab lights wont come on and a service 4wd message comes up. if i open the hood and hit the fuse box everything kicks on and works fine. i can still turn on the head lights manually. i figure its a conection in the fuse box but not sure what, any clue?
Old 06-15-2010, 08:50 AM
j cAT j cAT is offline
Re: 05 z71 with fuse box problem
remove the fuse box after you check all your grounds and feed connections ..that means removal, clean, [wire brush] torque securely.
make sure the fuses have solid tight fit...some have found they are loose because of improper removal damages the fuse socket..
Old 06-16-2010, 11:20 PM
Alrighty, good to know before i rip it all apart thanks for the input.
