Go Back   Automotive Forums Car Chat > Chrysler > 300M
Old 06-14-2010, 09:05 PM
erocki300 erocki300 is offline
Help with Air Conditioner...
The air conditioner just started making a hissing noise when it is turned off. It seems to still be working ok. Any thoughts on what it could be?
Old 06-14-2010, 11:44 PM
consultIII consultIII is offline
Re: Help with Air Conditioner...
If the system uses a fixed orfice; it is just the high side pressure moving throught the orfice to the low side. A/C systems have a high pressure side and low pressure side. when you turn the system off the pressure from high side equallizes to the low side. It moves throught a calibrated restriction called a fixed orfice.
this occurs anytime the a/c is turned off ...you just can't hear it with the car running.
Old 06-16-2010, 12:51 PM
It stopped working all together now. Is this a switching problem and if so, how can you fix this without too much trouble?
Old 01-12-2011, 09:59 PM
cocks12 cocks12 is offline
Just check if the A/C is on but placed in low pressure volume. it makes hissing sound. but not to high sound. or take the a/c to a mechanic and check with him.
