Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-14-2010, 04:48 AM
jahnneysazftw jahnneysazftw is offline
battery problem. plz help!!!
i have a 2001 honda civic dx 2 dr. i swapped the alternator and checked the battery it checked out. the car turns on normally nd runs great. but i remove the negative and the car dies. something is not letting the battery charge. can someone please help me out!!!!
Old 06-14-2010, 12:38 PM
somick's Avatar
somick somick is offline
Re: battery problem. plz help!!!
If you removed the cable while the car was running - bad news! You could have killed the ECU.
If the car was running why did you remove the cable?
Here is the simple procedure to test your charging system:
a) Car not running - battery should read about 12.4 - 12.6 volts.
b) car running - check voltage at the battery terminals: it should read something around 13 - 14 volts.
For more sophisticated test go to Autozone. They test your system for free.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 06-14-2010, 01:54 PM
i removed the wire to chack the alternator. i was told thats how u can check it. thnx i will try that procedure out today and just to be sure ill also take it to autozone. do u think it will be something with the fuse box if it isnt the ecu??
Old 06-15-2010, 11:45 AM
somick's Avatar
I would pull out fuses one by one and check them for the continuity. Fuse may look fine but still be bad.
Good luck,
Sam
Old 06-19-2010, 02:24 AM
the charge was fine it turned out being a problem with the fuse box. thnx for the help.
i still need some more help. i want to start working on my car performance wise.
is there anything i can do to improve the torque of my honda?
