Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 06-13-2010, 11:42 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
t3/t4 downpipe
Can someone help me find a DP for a t3/t4 for my 95 rs. I have looked all over net and even ebay and I can't find 1 for any eclipse. Or could I use this and just cut the pipe I have now and just weld this to the end?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
Old 06-14-2010, 10:14 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: t3/t4 downpipe
I blieve only 1 company actually makes DPs for the 420a turbo, and it's about $250 if I recall.
I'm pretty sure that ebay listing will have the pipe facing the wrong way as is. You can buy just that flange and pipe and weld it up for cheap. Each one of mine I've done have cost no more than $50 in parts and I welded it up myself.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-15-2010, 03:34 PM
Re: t3/t4 downpipe
I looked around online and read that the best pipe to get was for an early to mid 90's civic, that it wouldn't be much cutting to line it up for a 420a. I took it to a guy in town and in about 2 hours he called back and said it was ready. He did a great job.
http://cgi.ebay.com/ebaymotors/ws/eB...97681&viewitem= This is what i bought.
Old 07-15-2010, 08:13 PM
david-b's Avatar
Dave is THAT guy
Re: t3/t4 downpipe
That looks pretty decent. How is the waste tueb going to get ran?
May I make a suggestion... put a 90* fitting on the oil feed line. I have mine the same way, and the hood hit it at some point once, kinked the line, and starved my turbo of oil. The fitting is only like $5, and will save you in the long run. It's a -4an 90* male to female fitting. Just a thought.
75 Monte Carlo
Old 11-17-2010, 04:34 PM
Re: t3/t4 downpipe
Ya I bought a fitting. But it's like the turbo sits so high up, it still hits the hood. I shut the hood and it broke my fitting also. Had to get another one. But can't close hood 100%.
Old 11-18-2010, 12:26 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: t3/t4 downpipe
Did you put a 90* fitting on the feed line?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-18-2010, 02:39 PM
Re: t3/t4 downpipe
Yup. But it hits the hood.
Old 11-19-2010, 01:16 AM
Holset powered 420a
Re: t3/t4 downpipe
You can clock the turbo slightly without having oil draining issues. This should fix it if it is barely hitting the hood. Otherwise you might be able to remove that flange adapter thing you got going on and get a screw in fitting, might lower it a little bit also
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-19-2010, 06:31 AM
Re: t3/t4 downpipe
Ya I have a screw in fitting sitting somewhere I was using before. Thinks it's in my tool box. I'll try to clock it alittle and put the fitting back on and see if that helps.
Old 11-19-2010, 09:02 AM
david-b's Avatar
Dave is THAT guy
Re: t3/t4 downpipe
I'm confused by this. The feed line you have now doesn't hit the hood, but with a 90* fitting on there it does hit the hood? That doesn't make sense. The 90* fittings are tiny
This was how mine was with my bigger turbo sitting right at the front of the car, and it cleared perfectly and then some. I don't understand why a 90* on your setup sitting farther back wont close the hood.
75 Monte Carlo
Old 11-19-2010, 12:13 PM
Re: t3/t4 downpipe
The feed line hits the hood also, even without the elbo installed. It's like the turbo is sitting to high up or someting. I got it clock pretty much as far as urs. Scared to go anymore, cause IM not sure the oil will drain good enough.
