Old 06-13-2010, 12:47 PM
svotta svotta is offline
spark plugs
how do you get to the rear spark plugs on a 1990 lumina with the 3.1? the fronts are easy but the back I cant see and I don't kniow how to pull the motor foward.
Old 06-13-2010, 02:21 PM
maxwedge maxwedge is offline
A990 racer
Re: spark plugs
Unbolt the front upper dogbone mounts and pull the engine forward, then I block the engine in that position using a piece of 2x4 between the firewall and the engine.
Old 06-14-2010, 09:59 AM
Re: spark plugs
do I leave the car in park? and the engine will just pull foward when i unbolt them and pull?
Old 06-14-2010, 11:47 AM
A990 racer
Re: spark plugs
You could put in neutral, block wheels, the engine rocks forward fairly easy, but I am 225 lbs, you may need a pry bar to do this?
