Old 06-12-2010, 10:07 PM
Mustang-Josh98 Mustang-Josh98 is offline
95 Taurus Rear Disc-Brake problem!
I tried to replace my rear pads today. One of the calipers wont seat. And this is the thing, its only 3 1/2 months old. I replaced it myself because the original was leaking right around the piston. Kept ratcheting clockwise for at least 5 min, maybe 5 to 10 complete revolutions. The piston just wont retract! Still has about 3/4 of an inch to bottom. Am I doing something wrong? I'm thinking its defective. ( Job performed with Brake Master-Cylinder cap unscrewed and brake bleeder closed )
Old 06-12-2010, 10:52 PM
ricebike ricebike is offline
Re: 95 Taurus Rear Disc-Brake problem!
hope you have the receipt for that defective caliper
Old 06-13-2010, 08:00 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Rotating the piston by itself won't cause it to retract, you also need to apply pressure on it. The little cubes that go on the end of a socket wrench are difficult to use for this reason, in the event that's what you're trying. You'll probably need to borrow the rear disc brake compressor kit from your local parts store. Hopefully they have one in their Loan-a-Tool program similar to this one.
-Rod
Old 06-20-2010, 03:39 PM
fubard's Avatar
fubard fubard is offline
I just did this job on my 1995 .1 caliper was frozen tight and had destroyed the rotor. I replaced it and put new pads in the rear. WHen I went to do th eother side I could not retract the piston and I use a proper tool. I ended up replacing it , even though it was working fine !!!
GL
Autos fixed with help from this forum:
1991 Chev Lumina auto engine hurled
1990 Ford Taurus auto death by high mileage
1995 Ford Taurus auto sold !!!
1989 Ford SHO 5 spd, sold, too finicky
1991 Geo Metro 5spd, SOLD, still ran great
2000 Chev Metro auto sold , mileage was poor
1998 Firefly 3 cyl 53mg!! SOLD I don't commute now
1993 Mercedes 300E sold...looking for a newer one
1999 Mercedes ML320
2000 Taurus my wife's new ride. Bought with only 105K
It's almost a fleet !!
Old 07-04-2010, 10:11 PM
Time to update! Few weeks go by and I start losing brake pressure on the highway. Pedals dropping and it doesn't seem safe but the brakes are still working. I'm gonna replace my other caliper so both will be new. Went back to the parts store, bought the other caliper 53$ Installed it and the new pads-no problems! What did I walk away with from this one? When I went back to finish the left-side , which was the first side that failed. I realized you need to open the brake bleeder valve for the piston to retract! 1/2 inch drive ratchet and adapter did it! Didn't need to rent the spring compressor tool! Thanks for the posts!
