Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-12-2010, 06:27 PM
Badfish169 Badfish169 is offline
Coolant leak
91 cutlass ciera 3.3l 149,500 miles
I got this small coolant leak on the passenger side of my engine. The weird thing is it seems like it only leaks when the engine in cold.(I'm guessing it just evaporates when the engine gets hot)Water pump isn't leaking. I did my intake manifold gasket last year so that shouldn't be it.
I replaced the lower radiator hose since I thought thats where it was coming from. But now after My engine cooled off I can see a small amount of coolant leaking again.
There are no real puddles on the ground but on the frame by the motor mount i can see where it groups up.
If it was my timing chain cover it would be leaking oil.. so I'm at a loss with this one. It just bugs me and would like some suggestions to what it could be.
Old 06-12-2010, 07:44 PM
maxwedge maxwedge is offline
A990 racer
Re: Coolant leak
Get a pressure tester on it and the leak should be evident.
Old 06-12-2010, 07:58 PM
Re: Coolant leak
I don't really feel like spending 70 bucks for a tester.. Is there somewhere that will test it for free?
Old 06-12-2010, 11:29 PM
ricebike ricebike is offline
Re: Coolant leak
you can "rent" it... autozone has a free loan tool program
i believe other parts stores in your area can do the same
pepboys did back then, but i dunno now
advance auto parts has a similar loan-tool program
Old 06-13-2010, 05:44 AM
Re: Coolant leak
K thanks I'll give it a try
Old 06-13-2010, 10:56 AM
Re: Coolant leak
Did the test and it held steady pressure so I took a closer look and it looks like it's coming from the timing cover gasket where the coolant flows through it. Good news is that its not mixed with the oil. Should I be in a hurry to change the gasket?
Old 06-16-2010, 11:53 AM
Re: Coolant leak
Quick question,
I decided to change the timing cover gasket(and everything else it involves) and I am stuck at the crank positioning sensor. Is their a dowell pin in the middle of the CPS bracket to the engine block? I got the two bolts out that were holding it to the cover but it's stuck. I've searched for similar issues but haven't found an answer.
