Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-12-2010, 05:04 PM
bryansimmons24 bryansimmons24 is offline
01 Rodeo Misbehaving
Like many of you I am having many issues with my rodeo. Just recently I pulled the codes from the computer. I have 4 bad O2 sensors, random multiple cylinder misfires, crankshaft position sensor out of time, and the fuel level sending unit sensor. well I have a good friend who is a mechanic for these cars. His advice is replace the CPS sensor clean the EGR valve, and replace the fuel pump. that should clear the problems. I have yet to afford this but I will update as I go to advise all of you.
Old 06-12-2010, 08:58 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 01 Rodeo Misbehaving
Start with the CPS and clean the EGR and EGR tube ... the 02 codes may clear themselves up after this fix.
the fuel pump doesn't need to be replaced... there is a fuel sending unit that attaches to the pump that needs to be replaced.
Check out the FAQ link below for more info on these fixes.
How many miles do you have on your Rodeo?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 06-12-2010, 09:45 PM
Cat Fuzz Cat Fuzz is offline
I don't see how your CKP can be out of time. It's not adjustable. also, O2 sensor codes don't always mean to replace the O2 sensors. There could be another problem elsewhere that is causing the O2 sensors to be doing whatever they are doing. Can you list the specific codes that you pulled?
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
