Old 06-11-2010, 05:57 PM
jmartos jmartos is offline
'97 Grand Prix HVAC Problem
'97 Grand Prix HVAC, 2 problems.
1. Blower motor does not work on setting 1
2. Air selection only blows from top vents.
What could be the problem?
Old 06-11-2010, 10:32 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: '97 Grand Prix HVAC Problem
Welcome to AF.
Your post has been moved to its own thread.
1) Bad blower motor resistor or climate control unit switch.
2) Check the accessory vacuum line running from the upper intake manifold (back) to the area by the main fuse box. Check for loose connection or bad plastic vacuum line.
Timeslip 08/12/06
AF Community Guidelines
Old 06-13-2010, 09:32 PM
OK. I had a bad blower resistor.
Is the intake manifold in the engine compartment? I'm looking for the accessory vacuum line. Where is it and the main fuse box?
Old 06-13-2010, 10:25 PM
brcidd's Avatar
brcidd brcidd is offline
You can about bet that the blak plastic vacuum line is broken right near the battery- battery gases eat through the plastic-- reroute the line and splice in a new piece with a rubber hose-- I'd say I've repaired a couple dozen W-cars this way....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-13-2010, 10:36 PM
BNaylor's Avatar
Which engine do you have? The N/A 3800 or supercharged. I am assuming N/A 3800. The intake manifold is under the plastic injector cover so remove it first. Then you will see the upper intake manifold plenum (UIM) which is the black thing you see. On the back side of it towards the firewall is the accessory vacuum feed and feed to the power brake booster. Check that part and follow the smaller plastic line along the firewall over to the passenger side strut tower area. Then over along the inner fender which is where the main fuse box is located above the battery. There is a vacuum line coupler you need to check along with the complete plastic line.
Timeslip 08/12/06
Old 06-15-2010, 01:02 AM
It was the vacuum line in the exact location that you predicted. Thanks!
