Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 06-11-2010, 11:01 AM
samahi72 samahi72 is offline
97 Fuel Pump going Bad????
Another question on my recently purchased 97. The car has to crank for about 2-3 seconds before it will start. When I asked the previous owner about this, he told me to turn the key to the "on" position for a couple of seconds before engaging the starter. He said the fuel pump needed to pressurize the system. When I follow his directions, it does work but I am thinking that the fuel pump should be holding the pressure when van is off. Also where is the fuel pump located?
Thanks
Old 06-11-2010, 11:15 AM
mechanic1980 mechanic1980 is offline
Re: 97 Fuel Pump going Bad????
The fuel pump is in the tank and it does hold pressure but not forever try a fuel filter first
Old 06-11-2010, 01:08 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Have you checked to see if the fuel pressure regulator is leaking? Pretty common on those as well as fuel injectors!
